メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech G300S Optical Gaming Mouse(2015年発売)の修理ガイド、分解情報、およびトラブルシューティング。
How do I open it without breaking it?
Title says it all- I'd like to inspect the inside to see why middle click sometimes does not work. I had an older one 5+ years ago that I replaced after the right click began double-clicking too.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It's usually the microswitches. You'll need to order a set of Omron switches like this: https://www.ebay.com/sch/i.html?_nkw=omr... -- mouse type really doesn't matter as they're all wired the same, but look for ones made for Logitech mice. You might need to order ~10 when you only need three, as most sellers insist on selling you 10 at a time in the US, so bear that in mind. It's usually best to do all 3 at once, since one failing tends to mean the others are next.
As far as opening it, look under the stickers on the top and bottom - that's Logitech's favorite hiding spot. Most of the time, I consider mice eWaste when they break, but gaming mice tend to be expensive enough that it makes sense to repair them if the parts are available and you can do it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
tyiscringe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 40
今までの合計 400
