メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nikon D3Xは、2008年12月にNikon Corporationから発売された24.4メガピクセルのプロ向けフルサイズデジタル一眼レフカメラ(DSLR)です。
Clock battery on D3x
I recently bought a second hand D3x, Im very happy with it. I read somewhere (?) that I may need to replace my clock battery. This makes sense to me as every time I take the battery out to recharge, it resets to 2007 and resets the counter. Where is the clock battery on this camera and is it something I can replace myself?
If I recall correctly they gave a battery type in the article, which I sensibly didn't write down.
I trust you can assist me with my current quest. Thank you in advance for being here in the first place.
Bebb
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Is this what you are looking for? Replacing D3 Camera Clock battery
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The clock battery is located in the roof of the main camera battery compartment, concealed by a slide out cover. Its easy to locate and the battery in question you require is a CR1616 - 3 volt battery which are readily available.
I find they last a long time having only replaced them very occasionally on both the D3 and D3X
さんによる
コメントを追加
The Clock battery is a 1616 cell battery. It is found by removing the main battery and looking to the top of the battery chamber, here you will see a sliding cover which if you slide out of the chamber will reveal the battery. Nice simple one when you know
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
david bebb さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 25
今までの合計 174
