メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Olympus OM-D E-M10 Mark IIは、2015年に発売された16メガピクセルのミラーレス一眼カメラです。使いやすいプラットフォームによりレンズ交換が可能で、初心者にも扱いやすく、かつプロ仕様の機能を備えながらもアマチュアカメラマンでも購入しやすい価格設定になっています。
Warning about internal temp to high
Hi! I have this camera and as soon as I turn it on I get error that the internal temp is to high and it turns off. I have tried updating to latest firmware via SD-card and that worked. I also bought another battery to see if that helps. It seems that the internal temp sensor is broken or something. Is there a method to "reset" internal temp sensor? Has anyone disassembled the camera and know if it is hard to reach the sensor to look at? What would the next step be?
Oh, I also tried putting the camera in the freezer for maybe 30 mins but I instantly get the high temp warning even after that
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Well I doubt resetting will solve your issue, the alarm it trying to tell you there's a problem something is overheating! Did you get the camera wet or bang/drop it?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The camera looks to be in perfect condition and i don't think there had been water. The problem is i have tested to put it in the freezer for 30 min but it warns of heat instantly antway
さんによる
@patrikradacic - it's possible a sensor has failed. But it's not wise to put cameras into freezers! In the warmer chilled section yes but only when placed is a plastic bag with as much air removed! As you don't want condensation to collect inside!
さんによる
コメントを追加
回答を追加する
Patrik Radacic さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 13
過去 30 日: 38
今までの合計 309
