Light control are jammed
Cannot turn on the light the controls had jammed
Your Grand i10’s light control is likely stuck because of a failed or worn combination switch, though it could also be a blown fuse or a dirty switch mechanism. Try gentle movement + contact cleaner and check the headlamp fuse. If it’s still jammed, the stalk assembly needs replacement — a quick and inexpensive repair at most workshops.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 31
今までの合計 187
