メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
key button not working
Few buttons not working
Update (11/23/25)
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Hi @fzengo
What is the model number of the microwave oven?
Which buttons aren't working?
さんによる 共有
Model # MS14K6000AS
さんによる 共有
Currently now all buttons are not working
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
Hi @fzengo
Sounds like there's a problem with the control panel assembly.
You could try opening the oven and removing the control panel and then check if you can open the panel to see what's wrong.
Alternatively search online for a replacement control panel. Search for DE94-03322M to find suppliers that suit you best. (examples only). This is the part number for the control panel in the oven
Be safety aware when working inside microwave ovens. The HV capacitor in the oven can store >5000V DC for months, even if the power has been disconnected for this length of time. This amount of voltage can seriously injure you. The HV capacitor needs to be correctly discharged as soon as it can be accessed after the oven's cover has been removed and before commencing any further work inside the oven. If you don't know what you're doing, then don't do it! Contact an appliance repair service and ask for a quote.
Replacement assembly control panel for your Samsung 1.4 cu. ft. microwave.の画像
製品
DE94-03322M - Samsung Microwave Assembly Control Panel
$166.99
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
fzengo さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 84
今までの合計 726
