メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Valve製の人気携帯ゲームコンソールを2023年に刷新したSteam Deck OLEDの修理、分解、トラブルシューティング情報。2023年11月16日発売。モデル型番は1030です。
Steam deck Battery Health
When I got my Steam deck about a year ago, I would get 8-9 hours in half life 2 and 2.5 hours in cyberpunk 2077, now I get around 6.5-7 hours in half life 2, and 2 hours in cyberpunk, should I replace my battery soon, or wait a bit to replace it, the system still says its at 100% percent health but I don't believe that number entirely.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
could be dried thermal paste causing the CPU temperature to rise and requiring higher fan rpm to cool the console, drawing more power and decreasing battery life. Does your Steam deck feel hot when gaming?
さんによる
Not really, if sits around 65-70 degrees when playing a really heavy game like cyberpunk
さんによる
コメントを追加
1 件の回答
ベストアンサー
You probably shouldn't replace your battery right now. All battery age, but if there's only about an hour's difference in battery life compared to when it's new, replacing the battery now would be a waste. A new battery's both expensive and pretty hard to replace if it's your first time fixing stuff. If it works, it works. Wait until the battery life's significantly short or when it starts to bother you a lot, then replace it.
However, if you're really paranoid about battery life or feel like you'd like a few more minutes of cyberpunk, here's the guide.
Steam Deck OLED Battery Replacement
A lot of glue and fragile cables, so make sure you follow the steps carefully. It would be a good idea to read the guide before you actually start to replace it, to get a general idea of the steps.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
That's what I thought as well, I've repaired adhesive batteries before, but I agree that I should probably wait to replace it.
さんによる
コメントを追加
回答を追加する
Caleb さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 52
過去 30 日: 234
今までの合計 3,147
