メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Kenmore 110 Series は、Kenmore が製造した家庭用洗濯機で、使いやすい製品です。
Need schematic, Cannot find. Code F28
Hello. I need the schematic for a HE2plus Kenmore, model 110.47511701 . I have exhausted my search.
I am getting a code F28 after changing the door latch, the control panel and the inlet switch.
This machine will not start filling.
The drain pump was also replaced recently and worked fine.
The machine was reset numerous times and connections checked. The only thing left is to put a meter on it.
Any help will be appreciated. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Have you checked inside the machine for service sheets that are often stored there for technicians to use?
さんによる 共有
Yes, it is missing.
さんによる 共有
This model is made by Whirlpool.
さんによる 共有
コメントを追加
2件の回答
最も参考になった回答
Hi @rebeccatraub
Here's the tech sheet for the washer.
F28 is a communications error between the Control board and the User Interface.
You didn't specify which connections you checked but recheck the UI board to the Control board connections at both ends. Look for corrosion on the connector pins perhaps.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I'm still looking, but so far the only source I've found is a site called servicemanuals.net that claims to have the manual available for purchase in either digital or paper form for $16.99 or $29.99 respectively. I can't vouch for them, sorry to say, as I have had no experience with that site.
KENMORE 11047511701 110.47511701 Service Manual-Service Manuals
I did run across an eBay listing that said the part they were selling was from a washer with a quote:
Maybe double check any control board plugs that were disconnected or jostled?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks. I just ordered the info. Site looks a little sketchy but we will see.
Thanks again.
さんによる 共有
コメントを追加
回答を追加する
RJ Traub さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 30
今までの合計 181
