メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
第3世代Sony PlayStation 5 DualSenseコントローラーの修理ガイド、分解、トラブルシューティング情報。 型番はCFI-ZCT1W、マザーボードの型番はBDM-030です。
My controller shows 3 blinking lights yellow
I have a PS5 controller and I was upgrading to hall effect sticks and one thing i did notice before i finished it was that the the button for L3 had some of its lines i brushed it The image shows how it got damaged and i dont know if that is the issue or something else. i havent soldered my vibration and haptic wires yet too or is it a flux short?
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi!
First of all, I would repair the traces and get this fixed.
Then it's for the best to connect everything again and test the controller.
Here is a sample guide: How To Repair Damaged / Broken PCB Traces - 2 Great Methods
Please let us know how it goes!
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks, I will try it out as soon as I get some wire. One of my PCB pads was also missing, and I found a video from the same channel. I have a spare motherboard, which has a similarly sized pad, so I will scrape that one off and transfer it to the PS5 controller motherboard. I also found that one of my solder points was barely connecting to a different one, so it might be a short as well. I will be resoldering that, too. I will update ASAP.
さんによる
Alright! Sounds like a lot to do! Good luck with the repair and please let us know how it goes :)!
さんによる
コメントを追加
回答を追加する
Elvin Eve さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 42
今までの合計 279
