Mouse pad is stuck
My mouse pad is stuck and the left click is constantly pressed which makes the pad unusable
@ghost47490 start off by checking and adjusting the settings for your touchpad.
Through Windows Settings:
Through Control Panel:
If none of that will make a difference I would consider removing and checking the touchpad for and physical damage and/or replacing it. Use the HP Victus Maintenance And Service Guide and on page 59 it tells you how to work on it.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 45
今までの合計 850
