メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
「PS2」の通称で知られる、ソニーが2000年3月に日本で初めて発売した第6世代ゲームコンソールです。米国では同年の後半にSCPH-30000として発売されました。本デバイスの修理には一般的なツールしか必要ありませんが、少々コツが必要です。
Fat Ps2 Scratching discs?
画像
画像
画像
画像
画像
画像
画像
画像
Typically when discussing Ps2's that scratch discs, the slim is the first thing that comes to mind. I have however recently purchased an SCPH 50001/N model and noticed that mine is scratching discs a bit differently. After having searched many forums, I can not find so much information.
Here's the issue:
I have purchased games recently that were very clean (SCIII and SOE) and decided to pop them into the PS2. What I've noticed is that after 30 mins or so I receive a pattern of hair like circular scratches around the disc. Now keep in mind, these are not circles that ring around the whole disc, rather its a pattern of multiple circles around the disc. What could be causing this? If you need pictures I am able to upload but any help would be appreciated as I can't find anything.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi!
Could be multiple things.
1: The laser is replaced and not correctly installed (in height).
2: The top case has been replaced with another one, but is the incorrect type/version.
3: Disc drive isn't alligned properly (less likely).
4: Something is stuck inside the disc drive causing scratches.
Did you recently repaired the PS2? Or did the previous owner?
Replacing the disc drive is a option, replacing the top case is difficult as there are many versions out there.
If you can share some pictures, that would be great!
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
Hi there! Thank you for engaging with my post. I have just posted the pictures now. Let me know if you have any questions.
さんによる
Hi!
Yes, I would replace the top cover of the disk drive. There are 2 main versions out there.
1: Top loader with 2 clips and 2 screws.
2: Top loader with 4 screws without clips.
You need the 1st one. The one with 2 clips and 2 screws. I would replace that one and see how that goes. If the same issue occurs, I would replace the laser and check afterwards.
Still facing issues? Then you most likely want to replace the whole drive.
Please let us know how it goes!
さんによる
@dan0 Thank You. Just out of curiosity, do you see any issues with the top loader itself which causes you to suggest that?
さんによる
My pleasure! No I don't. It's hard to see with the eye. I know from experience that the top loader is usually the culprit..
さんによる
@dan0 Ok! I really appreciate your help!
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Tom19 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 54
All Time: 823
