メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Playback error with YouTube tv
Suddenly I get a playback error with YouTube tv when using my Epson 3800 projector. Worked fine until recently. No issues on tv's, just my projector. Any solutions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@shawneesteve does this only happen when using Youtube for playback?
さんによる
It happens when I try to watch live tv on YouTube TV. The other apps like Prime or Fubi work fine.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
It might be an HDCP error. Unless it has HDMI, HDCP support is not always present. What Epson projector do you have? Is it the Home Cinema 3800 or another model? Epson 3800 is ambiguous at best.
I have seen all of them (Dell, Epson, and the many others) produce VGA "EDU" projectors long after the mainstream got past VGA where HDMI became standard, and they flood the market when the schools dump them due to bad lamps and no HDMI many times. As much as I promote reuse, please do not buy these things*. They're not worth buying when HDMI models are as cheap or not much more then these compromised EDU models.
*They are fine for things like old game consoles except cases like the PS3 where you need a HDMI "splitter" or straight up stripper as the HDCP is always on, but old consoles and such are fine and work fine as they do not have HDCP dependencies.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Shawnee Steve さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 26
今までの合計 243
