メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Shark Rocket IX141は、SharkNinja社製のコードレス掃除機です。この掃除機は、ペットの毛を掃除するために特別に設計された強力な吸引力が特長です。
Why is there no suction
There are no blockages, the filters are clean, the roller is turning. But there is no suction. It worked yesterday before I cleaned it. Now it is clean and it doesn't work
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hello @laney89560
The fact that it stopped working right after cleaning the canister could hint at something that happened during the process. I imagine you have done it several times and are very familiar with all the pieces that have to go back inside the vacuum after a cleaning but do you notice any gaskets / seals / rubber rings or parts that help create suction missing from the canister or around the canister area? Something that could have accidentally detached / unglued / snapped while emptying the canister?
Alternatively, do you notice anything that might have gotten stuck where all the parts along the vacuum snap / click together? Or any damaged / cracked plastic that allows air to enter the system at a place where it shouldn't?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Laney さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 242
