Xbox 360 (Jasper) Not Turning on.
Well. recently i PicoFlashed my XBOX. after messing with dashlaunch, my NAND corrupted. so i picoflashed. the LOG if you want to see:
Initializing nanddump1.bin, please wait...
Header is wrong
Reading Nand to C:\GOG Games\J-Runner-with-Extras\output\nanddump2.bin
Read Successful!
Comparing, please wait...
Too Many Bad Blocks
Too Many Bad Blocks
Nands are the same
Initializing flashdmp.bin, please wait...
Glitch2 selected
Nand Initialization Finished
Checking Console...
Flash Config: 0x00000001
Writing flashdmp.bin to Nand
Write Successful!
The console is LTU (i think). Is jasper. pure. without RGH or JTAG.
Well. after the flash, we tried to turn it on. but nothing happened. the controller wont receive power. the brick stays orange.
i know the led on the brick changes according to consumption. without anything connected, the led is slightly weaker. with the XBOX connected, it gets a bit brighter. this is normal response. with the xbox broken or not. but, she stays orange. without trying to get on.
i could try to force her on. but i doubt that this would be a good idea. and probably some magic smoke you come off him.
Either i think maybe a small ball of Solder joint got off and its shorting somewhere else.
We shaken it a bit to see if anything would come out. bur nothing really came out.
Hi!
I can’t help you with the modding part. Did you tried another power block? Just to be sure. Otherwise it is motherboard related. Did you checked the capacitors and did some measuring?
koppie007 さんによる
@dan0
the poblem is that my multimeter is LITERALLY on life support.
i cant trust anything that comes out of him other than short circuit check.
well. the xbox worked fine before the modding. or better, nand flashing, i dont believe they spontaneusly decided to go bad.
i dont really have other power block. the max i have is some ATX PSU. there is other powerblock, but he have lower wattage, because is made for the X360 Slim.
Estrela Brisada さんによる
Then it's probably caused by flashing it... I can't help you with this, sorry :(. Ah yeah, that won't fit... You really need the power block for the first one.
koppie007 さんによる
It's possible that the console is bricked, especially because it sounds like you were modifying it beforehand.
Fixer of Stuff さんによる
@fixerofstuff Well, my intention was to somehow get a PS4 controller on him.
I Was using BadUpdate exploit. (With XeUnshackle).
worked fine. without any poblems. until i've entered dashlaunch.
for me, dashlaunch wont mess with the NaND. but, after clicking one button whcih i dont remember now what it was, but it did not say anything about the NAND, the console rebooted and well. 3RL, 0021.
after we flashed the NAND, again, it now remains on this state. wont even turn on.
we will get to a repair shop to see if can get fix, i would fix it myself. but i first need to learn about soldering, get a proper multimeter, and get a way around my ADHD. if i cant solder, and my multimeter is not properly working, is near impossible to fix the console by myself. (Yes, i came to realize that literally now)
i'm not sure if the NAND got bricked so hard that the console wont even turn on. he probably has some power issue. if the nand is still no good, it should turn on, and do a 3RL at least.
2件以上のコメントを表示
