メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ford ExplorerとMercury Mountaineerは、ともに2006年モデルで新しいフレームにアップデートされました。このフレームはTower Automotive社ではなく、Magna International社によって製造されています。
Consuming too much gasoline
Hi, I have a Ford Explorer 2006 Eddie Bauer Edition which currently consumes between 20 and 21 L/100Km, which is too much, i checked with forscan and it says the combustion is too lean or something like that, i checked and it says that i need to clean the MFA, done, check if there is a broken pipe, done, there was nothing, i dont really know what else to do.
===PCM DTC P0171-FF===
Code: P0171 - System Too Lean Bank 1
Module: Powertrain Control Module
Diagnostic Trouble Code details
The PCM monitors the adaptive fuel table to ensure fuel control system components do not vary from their nominal values. The fuel control strategy within the PCM uses the adaptive fuel table to compensate for normal wear or aging of fuel control system components. The code is set when the PCM can no longer compensate for additional changes in the fuel system.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@fabioelgamer since you've already checked your vacuum lines you may have to check/change your intake manifold gaskets. Those are the most common issues on that year of Explorer. I usually use some starter fluid spray and spray it where the intake manifold could pull some into the cylinders. If your engine starts to run different while gently spraying, you know it is sucking the starting fluid in through vacuum leak. Since you have to do that on a running engine, you really want to be careful of any moving parts as well as don't just blast that spray all over.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
FabioElGamer さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 12
今までの合計 187
