メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech Lift エルゴノミクスマウス。カラーはブラック、ホワイト、ピンクの3色展開です。
Left click button does work inappropriately,
Hi
I had used it around 10hrs every weekdays over two years, it is quite a long time use for daily basis because I am full time a drafter and designer. It started not reacting often with the left click button. yeah sometimes work sometimes not.
I've just replaced it with another new lift but if I can fix it, would glad.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
same for me. its a pity, i will reorder new one, but itl sure happen again. i didnt use it that much. but it happened after 2 years too
さんによる 共有
Right button is glitching for me. Purchased Aug 22.
さんによる 共有
コメントを追加
2件の回答
最も参考になった回答
@hyundongsung check your mouse and see if this is a mechanical or electrical issue. Use something like this teardown Logitech Liftの分解 to work on it. Check the plastic parts, the ribbon cable as well as the switch board. Let us know if you find anything that looks odd. Sometimes the top of the switches get wore down and the button does not reach deep enough to activate the switch. Adding a small piece of felt to the top of a switch can restore that function. If not, simply check the switches for function with a multimeter and see if they close the circuit when activated.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Disassemble it and resolder the left mouse micro switch. There's a many different suppliers, but average micro standard is universal. You can replace this with soldering iron or station.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hyundong Sung さん、ありがとうございました!
統計データ:
過去 24時間: 14
過去 7 日: 65
過去 30 日: 331
今までの合計 3,330
