メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to replace the keyboard
Now I will show you how to replace the keyboard of a Dell Inspiron laptop.
You have to prepare some equipment including a flathead screwdriver and a new keyboard.
Remember to remove all the peripherals like the AC adapter and battery from the laptop. Don't use a razor blade because it might leave some scratches on your laptop.
There are 8 steps in total:
  • First, slide two battery-release latches into the unlocked position.
  • Next, remove the battery from the battery base.
  • Then, turn over the laptop and open it.
  • After that, use a small flathead screwdriver to pry away 5 keyboard latches.
  • Next, you should carefully lift the keyboard.
  • Then, disconnect the keyboard cable.
  • After that, remove the old keyboard.
  • Finally, reverse the above steps to install the new keyboard.
I have just told you the steps to change the keyboard. If you have any questions, don't hesitate to contact us.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I need some images and instructions on each image
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
Hi @jaygizo
Here's the ifixit AST Ascentia 520iの分解 guide that may help.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Anh Tuan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 34
今までの合計 207
