メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015-2020年型Ford F-150は、フルサイズピックアップトラックの第13世代です。革新的なアルミニウムボディ構造、強力なエンジンオプション、先進的なテクノロジー機能で知られており、仕事から日常使いまで幅広く対応できる汎用性と性能を備えた車両です。
2016 F-150 Steering Wheel Control Module and Clock Spring
So I got my truck serviced and they confirmed these are the components that are bad. Problem is they wanna charge $900, no insurance or warranty helping, and I practically live paycheck to paycheck. Is it possible to fix these myself?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
@oldturkey03 The big problem is the left side lever (wipers, turn signals, high beams) doesn't work. Additionally all the controls on the steering wheel don't work. Less concerned about those. The big issue my brother raised about doing this at home is if the control module would need to be programmed.
さんによる
コメントを追加
1 件の回答
@hlasley "practically live paycheck to paycheck" I think we are all doing that right now. There just isn't any extra money is there. Anyhow, what are the symptoms for your failed module? Yes, It looks like it can be done as a DIY. Looking through the service manual right now but it's to big to post one here.
My biggest concern with that is always the air bag. I would hate for that thing to deploy while you work on it. Anyhow, start with videos like this one as well as for the module itself use this video
Yes, the module will have to reprogramed by using a Forscan unit. you may need to find someone that either has one of those or you will need to depend on your dealer. May still be cheaper then what they originally quoted you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
H. Lasley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 50
今までの合計 586
