How fix code p2004 problem with check engine on
Code p2004 intake manifold
この質問は役に立ちましたか?
@hassanrami actually the P2004 code stands for "the PCM has detected the bank 1 IMRC actuator is stuck in the open position" This is a common issue with your Rogue model. Nissan even issued a Service Bulletin on how to resolve this issue. Following those directions should fix your code as well
このアンサーは役に立ちましたか?
Intake manifold runner control stock open bank 1 that's scanner show me
@hassanrami IMRC - Intake Manifold Runner Control; exactly what @oldturkey03 said.
過去 24時間: 2
過去 7 日: 13
過去 30 日: 69
今までの合計 987
