メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Bissell SpotClean ProHeat 5207Uは、小さな局所的なシミやこぼした汚れに対処するために設計された、コンパクトで持ち運び可能なカーペットクリーナーです。内蔵の加熱エレメントで頑固な汚れの除去を助け、カーペットや室内装飾品の清潔さを保つための便利なソリューションです。
Leaking from the bottom
Why does it start leaking when I connect the clean water tank? I replaced the tank and it’s still leaking as soon as I connect the tank.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
When you place the tank in the unit, it allows water to pass through a hose to the water pump. It sounds like your hose is leaking or disconnected; first thing I'd do would be to open it up and check the to see if that's where it's leaking from.
Fortunately, someone else has already run into problems with their carpet cleaner and created guides to a few repairs, and luckily one of them shows how to replace that hose.
Bissell SpotClean ProHeat 5207U Hose Replacement - iFixit Repair Guide
Keep in mind you may not have to replace the hose if it's just come loose from one end, but take it out and examine it for any cracks or bulges that might be leaking. Check the connectors on both ends of the hose for any cracked or broken plastic that could be leaking. After you open it up to where you can see the parts, you could put the tank back on and at point the leak may be obvious.
Best of luck; come on back and let us know what you find - your experience may well help the next person who has a leaking carpet cleaner!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tammy80 さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 14
過去 30 日: 63
今までの合計 625
