メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年モデルのRetina MacBookを早期にアップデートした2016年モデルの修理情報と修理ガイドです。モデル A1534 / EMC 2991
MacBook Model A1534/EMC 2991
It suddenly closed and won't open. Have they recorded any other faults and what could be wrong?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Can you give us a bit more here, what 'Closed and won't Open' and who is 'They recorded anny other faults' ??
If you struggle with English just tell us in your language (Greek?) as fully as you can.
さんによる
Helo Dane,
Thank you for the response.
Troubleshooting – MacBook A1534 EMC 2991
While in normal use, the MacBook suddenly powered off. On restart, it displayed the attached screen and has not functioned since.
Attempts to reset/restore (SMC reset, NVRAM reset, and other key combination procedures found online) did not produce any response.
Initially, when connecting the charging cable, the charging indicator light would turn on, but after several attempts it no longer shows any charging activity.
Has anyone experienced a similar failure on this model or can suggest possible diagnostic steps? Any guidance would be greatly appreciated.
________________________________________
さんによる
コメントを追加
1 件の回答
ベストアンサー
Sadly you likely have a dead battery here as most batteries just can run past 8 years even with the best of efforts. This first generation of USB-C charging also makes it hard to diagnose as they just don't have the onboard charging LED the older MacBook's had. Today with the reintroduction of MagSafe we gained it back. For now you need an inline USB-C power meter to monitor things. To make sure the battery alone is the issue. In any case here's the needed part MacBook 12" Retina (Early 2016-2017) Battery and here's the guide to put it in Retina MacBook 2016 バッテリーの交換
Replace a 5474 mAh battery compatible with MacBook 12" Retina (Early 2016-2017). 41.4 Watt Hours (Wh), 7.56 Volts (V).の画像
製品
$119.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ΔΗΜΗΤΡΗΣ ΚΑΛΗΜΕΡΗΣ さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 23
今までの合計 383
