Oil pressure warning light
The car is giving me an oil pressure warning light and keeps say stop the car and look at car manual
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント:
Hi @khotsochappie
What year is the vehicle?
have you checked the oil level on the engine oil dipstick to make sure that it is at the correct level?
さんによる 共有
Hi @jayeff
Thank you for responding.
I’ve checked the oil level and it’s on the correct level. Is there any other issue that could cause it
さんによる 共有
@khotsochappie
Could be a faulty oil pressure sensor or a problem with the wiring connected between it and the engine management control module, or worst case it's a faulty oil pump in the engine.
Best to get it checked out as you don't won't the engine to seize due to no oil lubricating it when it is running if it is the oil pump.
What year is the vehicle you never said?
さんによる 共有
I’ll do so thank you so much. It’s a 2014
さんによる 共有
コメントを追加
