メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to fix monitor?
I had my laptop sent to a repair shop and they returned it fixed, so i turned it off to get dinner and when i returned, it doesn't connect to the monitor. I used an external monitor and i saw that it only scanned my external monitor and not the laptop monitor. Is this somewhat a broken connection or just a loose port? HP 15s-du2034tx
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント:
Hi @keima30928
Do you mean that nothing is shown on the laptop screen, only an external monitor, or when the external moniter is plugged in it only shows on that, not the laptop screen?
さんによる 共有
@bananakat12345 The laptop monitor is no longer read by the device, when i check in settings on display. Only the external monitor is found
さんによる 共有
Also Idk if this helps but, on rare occasions, when i boot the laptop up, the laptop monitor and the external monitor lights up showing a glitching display, like a broken tv display of rapid movements, usually pinkish in color. And after i restart the laptop, everything goes back to normal, and the laptop monitor is once again, not read/scanned by the laptop, only the external one
さんによる 共有
コメントを追加
2件の回答
It might be a loose connection on the motherboard maybe the repair shop didn't route the display cable properly causing it to disconnect when the laptop is being opened and closed. Try opening the back plate and see if there is any loose connection if not check if the screen is Bron broken by flashing lights on it to see if there are cracks also check If it didn't get wet.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi @keima30928
There may be an issue with How multiple screens are set up.
Try pressing windows key + P key to open the windows project menu and ensure it is set to duplicate or extend (whichever is your preference)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Keima さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 297
