My headlight is not working
My headlight is not working. Please tell me what to do?
@sachinboora check the headlight bulb. Make sure that it is still working. Next check you wiring. Use a voltmeter on the connector for your bulb. Do you show the proper voltage on the connector when you turn the headlight on. If not, check the fuses as well as the headlight switch for your light. Let us know what you find out.
Use the schematics to trace the errors.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 23
今までの合計 238
