メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Appleの主要モデルである2021年のiPhoneは、9月24日に発売され、6.1インチの有機ELディスプレイ、デュアル12MPカメラシステムを搭載し、5色のカラーバリエーションが用意されています。iPhone 12の後継モデルです。
Post battery replacement verification and charging
I replaced battery replacement for my iPhone 13 and I have recalibrating it 2 times but my phone still tells me that the battery is unverified and an unknown part.
It also takes about 2 hours for it to go from 24 percent to 80.
I don't know if there is a way I could fix this because this is my first time handling an iPhone replacement and I'm afraid I messed up and have to get a new phone.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Startng with the iPhone XR, Apple started pairing the battery to the logic board. No, there isn't any reason to do that other than to discourage self- and third party repairs.
Since Apple is the only one who can do that parts pairing, any replacement, even when done with a genuine Apple battery, is going to result in the messages you're seeing. It's my understanding the pop-up messages will stop in about a week, but the badge on your Settings icon will be permanent.
In addition to the genuine parts message, the ability to view your battery health information is disabled, making it difficult to know when the next time you need to replace the battery is.
There are, however, ways around the issue. One is to transfer the BMS, or Battery Management System, from the old battery to a new cell. This will keep the warning message from coming up, and allow you to keep viewing the health info, but unfortunately it will carry forward the old battery's health information, which will now be wrong.
In the case of a genuine Apple battery, Apple has relented somewhat with the release of iOS 18 and included the Repair Assistant that will let you pair your new battery to your phone, fixing the issues. Sorry to say this won't help you with your aftermarket iFixit battery; to the best of my knowledge I am fairly sure iFixit does not sell genuine Apple parts.
You could also make use of the Apple self repair program, but my understanding is it's not that much cheaper than just going to the Apple store and having them replace it.
The upshot is that you didn't do anything wrong; Apple is deliberately putting obstacles in the way of you being able to fix your own phone.
Now, on your other issue, that of the short battery life, that sounds like an issue with the new battery. The good news here is that iFixit has an outstanding 1 year warranty on batteries and you shouldn't have any issue getting a replacement under warranty. Best way I know of to contact them regarding the problem you're having (the life of the battery, not the health/warning issue) is to email them at support@ifixit.com. I've found them to be responsive and helpful when I had a battery issue with one I bought from them.
Update (08/06/25)
I should add that other than the warning message and the health information, any replacement battery, whether genuine Apple or not, will charge and power your phone without any other problems.
Update (03/15/26)
It appears that beside the addition of the Repair Assistant, iOS 18 gives another benefit; it no longer disables the viewing of battery health information on aftermarket batteries, leaving only the warning messages as a deterrent for using non-Apple batteries.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
is it a genuine apple battery ?
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
It says unknown when I look at battery parts but I did order it from Ifixit so I'm hoping that it is.
さんによる
@truste it is probably just a standard battery that ifixit sell, a genuine battery will have the apple logo on it.
さんによる
Just to clarify here, Apple will not sell parts for resale to anyone but authorized Apple retailers, so iFixit cannot get genuine parts from Apple. So yes, it is an aftermarket battery if you bought it from them.
Be aware that even a genuine Apple battery will still say it's an unknown part unless you have an iPhone 12 or later, iOS 18 or later, and subsequently run the Repair Assistant.
さんによる
コメントを追加
Ideally the board containing the id chip on the old battery should be cut off and fitted to the new battery. Spot welding is the best way but you can get specific solder for the job as well. It's not something you have done, more what apple have done.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Trust E さん、ありがとうございました!
統計データ:
過去 24時間: 31
過去 7 日: 237
過去 30 日: 1,042
今までの合計 9,066
