メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年10月に発売されたGoogleのスマートフォン、Pixel 7の修理および分解情報。モデル番号はGVU6CおよびGQML3。
Screen detached from plastic safety frame
The battery was swollen and pushed the screen out, and when opening the phone I didn’t realise that instead of separating the screen with its frame from the chassis I was actually separating the screen from the safety frame.
画像
The photo above should make it clearer.
Now I imagine the obvious answer would be to get a replacement screen but tbh having already spent 80€ for the battery kit I don’t think it’s worth it (also the screen is fine)
Any chance I can reassemble the screen and frame? What glue could work?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I ended up carefully cleaning frame and screen with isopropyl alcohol, then used a thin layer of T8000, let it dry a few hours before proceeding with reassembling the screen to the device, and finally leaving the phone under a stack of books for 24 hours.
I guess I'll have to report back in some time to see if it holds, but for now the result was quite good. It's most likely not waterproof anymore but I mean, at least it won't blow up anymore.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Giorgio さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 20
今までの合計 216
