メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xiaomi Poco M2 Proは、2020年7月にリリースされたXiaomiのミッドレンジスマートフォンです。6.67インチのIPS LCDディスプレイ、48 MPのメインカメラ、5000 mAhのバッテリーを搭載し、側面指紋センサーを備え、Snapdragon 720Gで動作します。
Why it is not taking charge
Before it gets discharge it was running smoothly
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@shreyansh44195 The very first thing I would suggest you do, is to change your battery.
If a new battery still does not charge, you will need to check/replace the charging board and flex cable. Check that for micro tears and corrosion and proper connection to the boards.
Of course, you want to check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the port or the charging circuit.
Since iFixit does not yet have a specific guide for this, use something like this video to work on your phone.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My phone switches on and off.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shreyansh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 191
