How to check engine oil level?
@abelsebolao the Mercedes Benz W203 engines do not have a oil dipstick.
Here are the steps from the owners manual to check the oil level. The engine must be warm, car parked on a level, wait 5min after you turn the engine off.
Insert the key and turn the ignition to position one (the first click).
このアンサーは役に立ちましたか?
No dip stick!!! What on earth do Mercedes-Benz engineers have against checking the engine oil the old fashion way? I will stick (play on words) with Japanese made autos. Tops in the field.
All vehicles have a oil dip stick. Find it. Check the level when cold. Keep the oil level at max level for best performance and longevity. Google your car to find it.
このアンサーは役に立ちましたか?
The w203 as many other cars does NOT have a dipstick.
Checking Oil level is only possible via onboard system.
In this case:
Turning key and navigate via buttons on wheel to "check oil" section. Car has to stand still for a few minutes for the process to start. It is recommended to stand on even ground and use a cold engine for accurate results.
過去 24時間: 8
過去 7 日: 18
過去 30 日: 61
今までの合計 978
