メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LenovoのThinkPad X1シリーズにおける第1世代のコンバーチブル2-in-1ノートパソコン。14インチのタッチスクリーンを搭載し、付属のスタイラスペンを使用できます。2016年発売、モデル番号は20FQ00****
Replacement Battery Not detected
May I have team opinion on why the replacement battery not detected as if not connected?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Most laptop and cell phone batteries have a small circuit board called a Battery Management System, or BMS, built into them that communicates with the processor to provide information such as amount of charge, current flow and temperature. For some reason the CPU in your ThinkPad can't seem to talk to the replacement battery, so it thinks there isn't one connected. If you put your old battery back in and it works correctly, then I'd assume you simply got a defective battery. It happens.
If your old battery works fine, I'd suggest contacting your supplier about a replacement.
If your old battery is no longer detected either, I'd check the connector on the motherboard for damage. Look for any bent or broken pins; bent ones can sometimes be straightened with a pair of fine tip tweezers, but broken or missing pins would obviously be a more serious problem.
Update (07/18/25)
Lenovo has support pages for its products, and one of them does have instructions on updating the BIOS. Here's what I found.
Popular Topics: BIOS, UEFI - Lenovo Support US
I see no reason why your old battery shouldn't continue to work after a BIOS update. I assume the iFixit staff wants to make sure that the problem isn't an outdated BIOS that doesn't know how to talk to their battery, which may use newer protocols than your existing battery, so that may take a BIOS update.
I wasn't aware you had bought the battery from iFixit; I'm not an employee, just a volunteer moderator, so if you want to talk to them directly in the future regarding iFixit products, you should go ahead and post on their meta.ifixit.com site or email them directly at support@ifixit.com.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
IFIXIT asked me to update BIOS before sending a replacement, but i got lost in the provided link on how to update BIOS Are there any step-by-step processes to do that? If I update BIOS, and the new battery doesn't work, can i use my old battery after updating the BIOS?
さんによる 共有
コメントを追加
回答を追加する
Waleed s さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 71
今までの合計 761
