メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018-2024年型Toyota Camryは、世界戦略車Camryの第8世代にあたり、XV70として2017年1月の北米国際オートショーで発表されました。
Recirculation Button not working
My recertification for the ac is not working button works but it does not change the flapper
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If your AC recirculation button works (lights up or clicks) but the internal air flap (blend door or recirculation door) doesn't move, it's likely one of these common issues:
Common Causes and Fixes:
  1. Blend Door Actuator Failure
    • Symptoms: Button responds, but no sound or movement from inside dash.
    • Fix: Replace the recirculation/blend door actuator (a small motor under the dashboard).
    • Location: Usually behind the glove box or center console (varies by vehicle).
  2. Stuck or Broken Flap (Recirc Door)
    • Symptoms: Clicking sound or no airflow change when recirc is pressed.
    • Fix: The flap might be jammed, disconnected, or broken — this requires opening the HVAC box (dash disassembly in many cars).
  3. Electrical Issue (Wiring or Control Module)
    • Symptoms: Button lights up, but no action or strange behavior with other AC controls.
    • Fix: Check fuses, wiring to the actuator, or climate control module (a scan tool may help here).
  4. Vacuum System Issue (Older Cars)
    • Some vehicles use vacuum lines to move the flap. If you have an older car:
      • Check for disconnected or cracked vacuum hoses.
      • Listen for a hissing sound under the dash.
What You Can Do First (DIY):
  • Listen carefully under the dash when pressing the recirc button.
    → No sound? Likely the actuator is dead.
    → Clicking sound? Gears inside the actuator are stripped.
  • Access the actuator (often behind the glove box), unplug it, and check:
    • Power at the connector using a multimeter.
    • Try swapping it with a known good actuator (if you have dual zone HVAC).
  • Use scan tools (for newer vehicles) to check if the HVAC system reports actuator movement or errors.
Search your car’s make/model/year + “recirculation door actuator” to find the exact part and location.
If you give me your car make, model, and year, I can give exact diagrams and steps to help you find and fix the issue faster.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Heidy Ortiz さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 53
今までの合計 509
