Blue screen on my hp
Why my laptop always restarting unexpected
A laptop that is constantly restarting unexpectedly due to a blue screen (BSOD) could be due to many factors. The next time it happens, take a look at the error code on the blue screen and search it up online. This usually points to the underlying issue. Here's a list of many common blue screen error codes:
KMODE_EXCEPTION_NOT_HANDLED
PFN_LIST_CORRUPT
IQRL_NOT_LESS_OR_EQUAL
KERNEL MODE HEAP CORRUPTION
MEMORY_MANAGMENT
Hope this helps!
このアンサーは役に立ちましたか?
Well I will suggest you to checkout the following video. As there can be multiple reason for this issue:
このアンサーは役に立ちましたか?
You can Run System Checks-
sfc /scannow in Command Prompt (Admin) – scans for system file issues.
chkdsk /f – checks disk errors.
Use HP Diagnostics (press F2 at boot) to test memory and hardware.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 24
今までの合計 301
