NFC chip replacement query
My NFC chip is faulty. I've done all the tests including the onboard hardware ones, but no success, so time to replace if I can.
does anyone know where it's located and if/how I can swap it out?
Hello,
Just a sanity check first,
The Fairphone 5's NFC antenna is a built-in part of the battery, (pins 3&4 on the battery connector.)
so you are able to swap out the antenna by swapping out the battery.
But the actual chip itself is soldered to the main board and is not designed to be user serviceable without considerable skill and tooling
the schematics list it on page 40 as U3902 and on page 76 as ST21NFCD/ST54F
Your best bet to restore this functionality is to contact Fairphone support directly and ask about a warranty repair
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 73
今までの合計 517
