Multiple screen touch not working
Multiple screen touch is not working in games
@abhishekke14815 does it only happen when you play the game or does it also happen when you try and use your phone etc.? If so, then it does sound like a failing touchscreen. It is part of the display assembly and you would have to change that to fix this issue. I this only happens when you paly a game then it may be a compatibility issue.
Since iFixit does not have a specific guide for this, use the one from here It was written in Spanish so use a browser that does the translating for you, if needed. Replacement screens are readily available.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 9
今までの合計 151
