メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dualsense PS5コントローラー用充電スタンド。
Replacement leaf spring contacts
Has anyone ever been able to find a good replacement for the flimsy leaf spring contacts in this charging dock? It seems like a common issue that the contacts bend and break (I knowingly bought a second hand dock that has a broken pin).
I've been unable to find a replacement I'm confident will fit/work. Googling it returns this Reddit post https://www.reddit.com/r/AskElectronics/... where someone else was also looking for the part, but was unsuccessful. If any electronics gurus could point me to a part that would be a good fit that would be great. If not, I'll probably blindly buy a few different ones and see if they work.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
I could not find any spring contacts with suitable dimensions anywhere. But I did manage to fix my dock by replacing the broken contact with a pogo pin instead. The pogo pin base was a bit too wide for the plastic housing that the springs poke through, so I had to widen the hole a bit with some emery cloth. It's not pretty but it works.
https://a.aliexpress.com/_EG8hpQS
SMD type 5mm pogo pins.
They come in blocks of two but I only needed one and didn't want the black plastic housing they come in, so I broke that off with some snips.
I used a hot air rework station to remove the old broken spring and to mount the new pogo pin in its place. Then I used my soldering iron to put some additional solder around the pin and pad to make sure it holds in place.
画像
画像
画像
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Nice fix, Jimmy. Thanks for sharing your work and information!
さんによる
コメントを追加
回答を追加する
Jimmy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 33
過去 30 日: 134
今までの合計 1,534
