How do I change fluids.
How can I change the transmission fluid? I don't see any drain plug.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@suzyloretta looks like your mower uses a Hydro-Gear 2200 Integrated Hydrostatic Transaxle EZT Series for the drive. This transaxle is factory filled, sealed and does not require oil maintenance. You can check the fluid level. For the How-To use the SM Hydro Gear 310 2200 EZT and check page 11.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 15
過去 30 日: 29
今までの合計 276
