replace the plastic shell of the case
my buds were run over by a car causing considerable cosmetic dammage and cracks but are still functional. just wondering where to find the plastic shell for the case so i can transfer the electronics over?
I encountered the same problem. There are two options: Buy a new case, which costs almost as much as new headphones, or make one yourself (for example, on a 3D printer) using scans of the case, which you can find online if you want. This is quite cheap compared to a new case.
このアンサーは役に立ちましたか?
@boomcorp thanks 🙏 I will try
過去 24時間: 1
過去 7 日: 7
過去 30 日: 52
今までの合計 742
