My iPad 5 not changing
To troubleshoot a device not charging, you can first try using a different charger to check if the charger is at fault. You can also try using a different wall outlet to make sure it isn't the wall outlet that's at fault. You should also inspect the charger and charging port for any visible signs of damage or debris blocking the charging port.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 13
今までの合計 158
