メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Huawei P smartは、中国の電子機器メーカーであるHuaweiが2019年1月に発売したAndroidスマートフォンです。32 GBモデルと64 GBモデルがあり、ハイブリッドデュアルSIMに対応しています。
How to replace charging system?
Charging system replacement.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
What type of charging system can I use as replacement for P20 or P30 Huawei phone
さんによる 共有
@samuelagu you are not telling us what the issues with your "charging System" are. If it just does not charge you may need to change the charging board. For that you will need to know the exact model number for your phone.
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
If you're talking about replacing things like the charging port then yes, that can be done. The parts I'd be looking at would be what's called the auxiliary or daughter board that the USB port is mounted on, plus there's an interconnect cable that provides the connection between the motherboard and the daughter card. The following guide should give you all the information you would need to replace either or both parts.
Manuales / Huawei P Smart (2019) / Auxiliary plate - Nadie Me Llama Gallina
If you're talking about something like the power management chip, that's an entirely different subject. Replacing components like that mounted on the motherboard requires microsoldering expertise and equipment that is pretty far outside the skill set of most DIY-ers.
If I've missed something or misunderstood what you're trying to do, feel free get back to me in the comments and clarify what your goal is.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
@piousmavuso9647 you are not telling us what the issues with your "charging System" are. For now, I would suggest you replace the charging board (sub_board). Since iFixit does not yet have a guide for that, use something like this video to work on it.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Pious Mavuso Bongani さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 296
