メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Latitude E5570の修理情報およびトラブルシューティング。本機は、第6世代Intel Coreプロセッサを搭載した15.6インチのビジネス向けノートパソコンです。2016年に発売されました。
Black screen of death
So when I turn on my laptop I get greeted with a black screen, some trouble shooting I have done it trying to reinstall windows (I still saw black screen), when i press caps lock nothing happens, when I try to open bios nothing happend, i have tried reseating ram, using a differant hard drive, doing a hard reset, took out the cmos battery then put it back in, tried plugging it into moniter with hdmi and vga, nothing works,
Any help would be appreciated.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Does the screen turn on but not show anything or can you see the backlight on?
さんによる
@uptempoguy the backlight is not on at all. the screen is copletely black, same as when its turned off
さんによる
コメントを追加
1 件の回答
@heathbrown43963 check your backlight (most likely not the issue sine you also have no pictures on an external monitor). Turn your computer on and in a darkened room, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
It is possible that this is a bad BIOS. You may need to consider reflashing it. Of course, there is also a possibility that this is a failure of your GPU circuitry on your motherboard.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Heath Browning-Davies さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 24
今までの合計 344
