メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年7月に発売された15インチMacBook Proです。モデル番号はA1990です。15.4インチ LEDバックライトディスプレイ、True Toneテクノロジ、TouchIDと最大6コア Intel Core i9プロセッサを搭載しています。
Battery changed - still shows Service Recommended
I changed the battery and got the computer all put back together. It charges and seems to hold a charge longer . When I first powered on the Mac Pro - for a short time the Service recommended notice went away but is now back. I tried resetting the SMC but does not seem to have changed anything. I loaded Coconut battery and still shows the original battery information.
画像
Could there be an issue with the Battery Board Data Cable if it isn't seated properly ? Wanted to ask for some advice before taking the computer apart again
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Did you install a new battery or an already used one?
さんによる
A new battery from iFixit.
さんによる
@livfe that was my doing since it worked for the OP, it is a great answer that will potentially help many others. I did change it back
さんによる
コメントを追加
2件の回答
最も参考になった回答
Let's see if a hard SMC reset fixes this. Carefully disconnect the batteries connection, leave the Battery data cable connected. Now press the power button and hold it for a good 15 sec's this drains the charge within the logic board. Now plug in the MagSafe to power the system I haven't tried this yet on a M Series system so I'm sure what will be the reaction. Intel system tend to spontaneously restart. Give it a chance, then disconnect the MagSafe charger and reconnect the battery and restart the system did that alter CoconutBattery give it a good minute to recache the values.
このアンサーは役に立ちましたか?
スコア 1
12 件のコメント:
Thanks! I'll give it a shot and report back
さんによる
Open finder, preferences, select to show your macbook (Under iCloud), user name / library / com.apple.power (3 files) - delete them, empty trash, restart.....
さんによる
I disconnected the battery and pressed the power button for quite a while (more than 30 seconds). When I plugged the charger in - it stayed dead. No sign of life after waiting a bit. I disconnected the charger, connected the battery and had some trouble getting it to turn on. I needed to plug the charger back in and then it restarted. Unfortunately CoconutBattery still thinks it is the old battery and still recommends service for the battery.
さんによる
@laurenf48722 Did you try this? Open finder, finder preferences, select to show your macbook (Under iCloud), user name / library / com.apple.power.plist (3 files) - delete them, empty trash, restart..... (com.apple.powerlogd / com.apple.PowerManagement / com.apple.PowerManagement*)
さんによる
@laurenf48722 - See if deleting the files Livfe pointed to fixes things.
さんによる
7件以上のコメントを表示
コメントを追加
I'm in this position now, replacement went great, but it's still showing as "service recommended". I've deleted the power profiles in /Library/Preferences and after a reboot it's still showing the same message. I'm on a Macbook Pro A2338 M2, running Tahoe.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lauren F さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 22
過去 30 日: 128
今までの合計 1,705
