Hp-dk1074nr broken screen
I have a broken screen on my HP- dk1074nr laptop. What are the step by step procedures for replacing it?
Here's the maintenance and service guide, taken from this support page for the laptop.
Go to p.56 (64 of 96 pdf) to view the procedure to remove/replace the display assembly. The LCD panel is being removed during the procedure.
There are 5 different LCD panels that can be used in the HP 14 laptop series - see the HP part numbers for the Raw display panel (14 in) on p.56.
If the product number for the laptop as shown on the product information label on the bottom of your laptop is 2Z802UA, there are two LCD panels that can be used. The HP part numbers for the LCD panels are L25980-001 and L53828-001
If the product number for the laptop as shown on the product information label on the bottom of your laptop is 2Z802UAR, the HP part number for the LCD panel is L53828-001.
Search online for the applicable to your particular product variant part number only to find LCD panel suppliers that suit you best. Usually the part number can be found somewhere on the back of the LCD panel if you wish to verify which one it is.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 12
今までの合計 189
