メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP EliteBook 840 G3の修理情報。このHewlett-Packard製ノートパソコンは、企業での使用を想定して設計されています。
My display is glitching
I don't know if the problem is with the display or the RAM I will try to connect a external monitor later. When I am using the laptop while glitch screen it seems to get worse but it doesn't seem to compromise with the performance I hope it is an easy fix i think it's the problem with the display because few days ago I was carrying the laptop in my bagpack which was heavily packed
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@arzaanali "glitching" i really not anything that describes what issues you are having. You do want to go ahead and give a better description of what the issues with your screen are.
さんによる 共有
コメントを追加
2件の回答
ベストアンサー
Hi @arzaanali
Try this....
go to:
https://ftp.ext.hp.com/pub/caps-softpaq/...
Use HP Image Assistant (HPIA)
to download the correct drivers and bios update on your pc.
Run the tool and click Analyze
Allow for some time to capture system configuration,
and install all packages that was listed on it.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I HATE HP the next day the glitching problem was solved but today the laptop is not starting when I plugged it in the capslock button and the power button keeps blinking pls help
さんによる 共有
コメントを追加
My laptop display is glitching, likely due to physical pressure while in a tightly packed backpack, and although performance remains unaffected, I suspect a display issue and plan to test with an external monitor.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Arzaan Ali さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 450
