メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年10月に発売されたGoogleのスマートフォン、Pixel 7の修理および分解情報。モデル番号はGVU6CおよびGQML3。
Software problem or Hardware problem?
my pixel 7 have got some hanging issue like power button doesn't work properly if i press the power button then phone did restart so after that i backup all the data and did the factory data reset but after this my phone does not work and only i can see the google logo and restart again and again and only i can do is open fast-boot setting nothing else also if i choose between them then again restart problem what should i do
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
It sounds like your Pixel 7 is stuck in a boot loop after the factory reset, which can be frustrating. Here are a few steps you can try to fix it:
  1. Perform a Forced Restart – Hold the power button for about 10 seconds to force a restart. Sometimes, this can help break the loop.
  2. Charge Your Phone – Ensure your device has enough battery. A low charge can sometimes cause boot issues.
  3. Boot into Safe Mode – If possible, try booting into Safe Mode by holding the volume down button while restarting.
  4. Try Recovery Mode & Clear Cache – Boot into Recovery Mode and select Wipe Cache Partition. This clears temporary files that might be causing the issue.
  5. Flash the Factory Image – If none of the above work, you may need to flash the factory image using a computer. This is an advanced step, but it can restore your phone.
If your phone is still stuck, you might need professional repair or contact Google support for further assistance. Let me know if you need help with any of these steps!
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Still Not working my Bootloader is locked and OEM is also not unlocked what can i do now ?
さんによる 共有
@nishantkuma2956 I wouldn't count on any more help from Ziyaad. His answer is obviously AI generated and follow-ups aren't exactly in the AI bag of tricks.
さんによる 共有
@dadibrokeit if you know how to fix this dm me for the further communication ig:@n15hhuu
さんによる 共有
@nishantkuma2956 I'm sorry but I don't have any suggestions for fixing your phone; at this point it does sound like a hardware problem but I'm not seeing any clues pointing to what might be causing it. I mainly wanted to let you know that the original answer here is likely all you are going to get, as the writer most likely entered your question in something like ChatGPT and just posted the answer here, so it's doubtful they have any further insight into your issue.
Also, we prefer you don't ask for individual help by posting contact information. First, it opens you up to getting on spam mailing lists, and second by taking your discussion off the site, you deprive others of any learning you might receive. Since helping everyone is the goal of this site, that runs counter to their mission.
さんによる 共有
@dadibrokeit thanks for the information but i want to repair my phone i have brought it secondhand from the market but i think its software issue because i can open fastboot option easily but i cant do anything above this because if I choose between fastboot option the phone again restart and only google wordmark logo appears is there something i can do by my own laptop ?
さんによる 共有
コメントを追加
"I am facing a hardware issue with the display of my Google Pixel 7. The screen randomly gets stuck/frozen, especially during heavy usage or when the phone heats up.
However, the phone's system does not hang. Even when the display is completely stuck, the touch still registers (I can hear touch feedback sounds) and audio/background processes keep running perfectly.
I confirmed this by mirroring the phone to my PC using 'scrcpy'. On the PC monitor, the screen output is butter smooth and fully responsive to my touches, while the physical screen on the phone remains totally frozen. This proves that the motherboard, processor, GPU, and touch digitizer are perfectly fine. The fault is strictly hardware-related, likely a failing display IC, frame buffer, or flex cable that chokes under load."
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nishant Kumar さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 24
今までの合計 538
