メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
1999年式 Chevrolet Malibuは、General Motorsが製造した第5世代(1997-2003年)のモデルです。これは、1980年代初頭にMalibuシリーズが一時生産終了となった後、General Motorsが市場に再投入した最初の小型前輪駆動のMalibuです。
Why is my car lagging?
The car has a problem shifting gears and lags so much even a slight elevation is a challenge to clear.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
We need more details - is the CEL on? If it is on did you scan it? Id it just struggling without codes?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Without codes or any clues like climate, we will be limited here. We'll need more information like your climate and if you scanned the car, to give you an idea. Get the car scanned so we have more to work with. A scanner like this is plenty for you. Same as before, but offers bidirectional control.
The first thing I would check is the air filter. Have you changed it recently? If not, and it's more than a few years old, I would go ahead and try that first—NA engines and clogged filters do not get along and will behave this way. You can probably find this from your local auto parts store - this will run you $10-20.
The next thing I would look at is the MAF sensor—again, a bad MAF will do this.The quickest way to test this is to disconnect it, drive the car, and see if it behaves any better. If it does, then you have confirmed that the MAF sensor is bad.
NOTE: This test will trigger a CEL code, so get a cheap scanner before trying this. In addition, without a MY, we can't locate the part# for you - in lieu of a MY to locate it, search this: "XXXX(MY) Malibu MAF sensor".
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
John Manegene さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 180
