メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Poco M4 Pro 4G 発売日:2022年3月16日 179.5g、厚さ8.1mm Android 11、MIUI 13 for POCO 64GB/128GB/256GBストレージ、microSDXC
Charging problem to my phone
When I put my phone on charge it is not getting charge faster and having automatically charging on and off problem why it is happening?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
Hey there!
If I had to assume, I would say that your charging port has a bad connection to its PCB. Before you open it up to look, however, make sure you try a different cord and/or a different wall outlet to make sure they aren't the problem. I would also check your settings to see if you have "prioritized charging" or something along those lines turned on. The setting could be making your phone not charge at certain points.
If you have confirmed that everything I've listed isn't what's wrong, I would either open it to see if the charging port is bad, or even take it to a local repair shop to have it looked at.
Best of luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Poco m4 pro 4g speaker was filled by dust
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When I put phone on charging charging was soo slow
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bm amer さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 31
今までの合計 659
