メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
このページは、Sony PS2 Slimline (SCPH-750xx) のトラブルシューティングと修理ガイドのデバイスページです。Sony PlayStation 2 Slimline ゲームコンソールは、小型で薄型、ネットワーク対応のゲーム機です。
Disc Not Spinning Despite Fix
Hello, so just to sum this up:
I bought a PS2 from a charity shop that said it had a disc issue so I thought id just replace the disc drive, not a hard fix and a great bargain for £20
Ive changed the laser originally, didn't fix it, changed the whole assembly (the whole unit with the wires, thread bit to move the laser etc) still didn't fix it
So I bought a new unit altogether this time and still nothing, I'm assuming its something board related, so my question is
Firstly, what else can I do to fix this, and secondly if it is a board issue, where do I go about buying one? I've spent absolutely days researching now and I cant seem to sort it, any help is greatly appreciated as this PS2 is intended on being used for quite a while now
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
@jakeax3d we would really need to know what your board number is. Even better post some good pictures of the main board and let's see what it looks like. For now, I would check the connector for the optical drive (step 22 of this PlayStation 2の分解 ) See if you even have power going to your drive. Pin 2 is ground and pin 17 is VCC. After that I would check to see if the spindle motor gets power. Let us know what you find out. iFixitでの質問に画像を追加する方法
PlayStation 2の画像
ガイド
PlayStation 2の分解
難易度:
中レベル
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
このアンサーは役に立ちましたか?
スコア 1
9 件のコメント:
Hey, thanks for that, I'll try to get the photos for you tomorrow morning, but the one in the teardown you sent unfortunately isn't the correct one, I forgot there were 2 models, I have the one where the lid opens upwards rather than the tray coming out
さんによる
@jakeax3d sounds good. Let's see if we can get the Beast back to work again....;-)
さんによる
@oldturkey03 do you know by any chance where I can just buy a replacement board etc?
さんによる
@jakeax3d what board is? Remember there are a few different variations :-)
さんによる
@oldturkey03 to be honest im not sure, all i know is its a ps2 slim
さんによる
4件以上のコメントを表示
コメントを追加
A disc drive is specific for other models, check yours and check your disc drive if it's compatible. And if don't order compatible one. If you have any questions feel free to ask
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
i forgot to mention, i accidentally said disc drive when I meant disc tray, its the one that lifts up from rather than comes out
さんによる
コメントを追加
回答を追加する
Jake (AX3D) さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 328
