メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年9月25日に発売されたiPhone 6s Plusの修理情報と修理ガイド。モデル番号:A1687、A1634
Phone stuck on bootloop
Tried restoring/updating with iTunes and 3uTools with latest ios.
On 3uTools trying to "Fix Flash", it stops at 34%, on the "Updating NAND Firmware", after the phone shows the Apple logo and the update progress bar, then it hangs for a minute then reboot and returns to restore mode.
20:55:10.254:  Requesting SHSH
20:55:11.234:  Enter Recovery Mode
20:55:15.774:  Sending AppleLogo
20:55:15.803:  Sending Ramdisk
20:55:24.207:  Sending DeviceTree
20:55:24.222:  Sending RestoreSep
20:55:24.350:  Sending KernelCache << reboot to restore mode with the "Quick Flash"
20:55:32.333:  Restoring
20:55:34.497:  Sending RootTicket
20:55:34.501:  Waiting for NAND
20:55:34.514:  Updating NAND Firmware << reboot to restore mode with "Fix Flash" after 1 minute.
The battery was replaced 5-6 years ago, can this be battery related or a NAND failure?
Noticed that from uTools, if I launch a standard "Quick Flash" the phone reboot and goes back to restore mode after the "Sending KernelCache".
If I use the "Fix Flash" mode, it reaches the "Updating NAND Firmware" before going back into restore mode after 1 minute and no visible progress on the bar.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Update: Replaced the battery and the phone has same behavior.
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
I'd fit a new battery then try it if it's 5 or 6 years old. Also could need a new charge port if it does the same thing after a new battery. Older iphones can bootloop if the front camera ribbon develops a fault so it might be worth a try disconnecting it then trying to restore.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I was considering that but wanted to be sure it could be a battery fault and not a NAND or other problem, since i'll then remain with an unused full battery and a not working phone.
さんによる 共有
Were you able to get it working again? If so, how did you go about it?
さんによる 共有
@emerald83404 Replaced the battery, but the problem persists. Probably need a NAND reball / replacement but I have no instruments to do it.
さんによる 共有
コメントを追加
回答を追加する
Anachron さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 45
今までの合計 1,208
