メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Simple Way Pet Grooming Vacuum V10 XWLMQ01は、ブラッシングと吸引機能を組み合わせることでペットケアを簡素化するために設計された6-in-1グルーミングキットです。
How can I find replacement blades
How can I find replacement blades for my clipper for a simpleway model v-10 I’ve ordered from 2 different places including amazon prime and had to send back please help me find what I need
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Would also like an answer to your question Jeff
Tyman
さんによる
Hello - try IWEEL Replacement Titanium Blade with Moving Ceramic Blade for IW2691A Cordless Dog Clippers, Cat Shaver and Low Noise Water Proof Electric Dog Trimmer Pet Grooming Kit from Amazon. Pull silver pins from back & replace with the white ceramic teeth. Works wonders!
さんによる
コメントを追加
2件の回答
ベストアンサー
Hi @jefftyman
If you don't get a better answer perhaps try contacting the manufacturer and ask if replacement blades for your model are even available and if so are there any suppliers in your location that you can purchase them from.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
I have done that too. I’m talking about customer service and I’ve emailed and sent my number. I’ve did everything I possibly could not one answer.
さんによる
It makes me mad the company sell stuff like this, but don’t have any replacement parts for them
さんによる
@jefftyman
That seems to be the business model for more and more companies, i.e. cheaper product maybe but no support and no spares.
I'm learning to do a bit more research before buying as to what support/spares/warranty etc is provided by companies that I might buy from, before making a purchase.
It might cost a bit more buying from companies that do provide support/spares etc but in the long run it works out cheaper as the item can be repaired instead of replaced.
Cheers
さんによる
@jefftyman why do I think that those clippers are most likely just a rebrand from some other manufacturer? See if you can match the actual blades versus going by manufacturer.
さんによる
You may find codes imprinted or engrained on the blades, if those are to be had it's possible the internet or Amazon even has replacement options by other brands and codes. When I was trying to get batteries for my Lumix TS4 camera I used the code on the battery and received multiple options from other sellers as well as Lumix options.
さんによる
1以上のコメントを表示
コメントを追加
I am going through the exact same thing... I did get a reply from their support though that is STILL NO HELP! This is the reply:
Thank you for reaching out regarding your V10 clipper. We appreciate your patience as we look into your request.
Unfortunately, we currently do not have replacement blades for the V10 model in stock, nor do we have the full clipper unit available at this time. We sincerely apologize for this inconvenience and understand how important it is to have reliable grooming tools.
We’d be happy to notify you as soon as the items become available. Alternatively, or you can look for compatible blades
We apologize for the delay and appreciate your understanding.
Best regards,
Lilian
SIMPLEWAY
support@simpleway.com
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jeff Tyman さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 61
今までの合計 1,324
