メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GE電子レンジの修理および分解修理ガイド。
Exhaust not working properly
I have a GE Microwave model JNM7196SK1SS. The exhaust fan only works when the the unit is "cooking". In other words if I am cooking something with a lot of steam or some smoke and want to exhaust is away, i need to put a cup of water in the microwave and cook it until i am done.
Thoughts?
Thank you,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I have cycled the switch and it does not matter. I will check the Thermostat, thank you!
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @shawnbitner
Just verifying that you've tried pressing the Vent fan button on the control panel a few times to see if it worked OK i.e. once for boost fan speed, twice for high fan speed, a third time for low fan or a fourth time for off as described in the owner manual and it didn't work at any speed?
The vent exhaust fan is controlled by a thermostat (GE part # WB27X709), so presumably the fan only operates when the temperature in the oven is above the thermostat's set operating temperature but maybe not.
I can't find the mini manual (wiring diagram - GE p/n 31-30788) for the oven online which would help to show how the fan is controlled, but according to this GE article it may be behind the oven's control panel.
Here's a video that may help to locate the mini manual and the thermostat as well.
Be safety aware when working in microwave ovens. The HV capacitor in the oven can store >5000V DC for months, even if the power to the oven has been disconnected for this length of time. This amount of voltage can seriously injure you.The HV capacitor needs to be correctly discharged as soon as it is accessible after the oven's cover has been removed and before any further work is done in the oven
Activates the vent fan in your microwave when it detects a certain temperature.の画像
製品
GE Microwave Vent Thermostat Switch - WB27X709
$45.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Shawn Bitner さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 18
今までの合計 235
