メインコンテンツにスキップ
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
20回答 すべてを表示
MacBook screen white out? glitching?
hello first im korean so my english maybe not perfect sry :(
i bought used macbook pro 2015 15inch (since last macbook i bought wasnt able to fix)
i installed oclp (opencore legacy patcher) and bootcamp windows
everything works fine on windows but on mac os screen crackiling? glitching? like broken tv for 1sec and sometimes screen just turn to white or other color (gray,brown,rainbow etc)
i thought this happened after i install fmrte(i have to disable sip to lunch it) so i deleted it + return sip to normal but it wont work
have anyone know what cause it or how to fix it
thank u for reading long text
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I’m a bit lost here, are you running Windows or macOS and which versions as well as when, lastly, what are the Apps you are using.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
1. Windows 11 and mac os ventura 13.7.3
2. Fmrte is game editor I'm not sure but I think this glitching thing happened after I install and disable sip
3. I don't know this is related after enter password on mac os screen blink 1~2 times
さんによる
@srywhytnecqrdkc Try installing https://app-cleaner.com/ this app, select expert mode, allow access when prompted and it will remove ALL the associated files from this editor (or any other app for that matter) and see if that makes any difference. Also check for any remaining files after emptying the trash and a re-scan....
さんによる
Thnk you for advice I will try right now
さんによる
@srywhytnecqrdkc - Which OS are you used for Fmrte? I would focus in on that OS first.
さんによる
コメントを追加
回答を追加する
장우석 さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 23
過去 30 日: 23
今までの合計 23
