メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Only power button working of keyboard.
My laptop's model is acer aspire 5 a515-57g and has white backlight keyboard.
my laptop's keyboard is not working. but only power on and off function is working. when i try to go into bios at the time of booting my laptop there also my keyboard doesn't works like all keys are disabled except power button. But the backlights of keyboard are turned on every time when i start laptop.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Does it boot into OS ok?
Have you tried an external keyboard, via USB?
さんによる
コメントを追加
1 件の回答
@rutwikbelsare try a USB keyboard and see if you can access your BIOS etc. with that. Your keyboards backlight working is not an indicator that your keyboard is actually working. I would suggest that you open your computer up and check the keyboard cable. Make sure it is properly seated, does not show any damage or even corrosion. If you find that all of that is properly connected, you want to consider replacing the keyboard. It is a total PITA since it is riveted, but it is possible.
Since iFixit does not yet have a specific guide for that, use something like this video to replace the display assembly. Slightly different model but the work is identical. Replacement keyboards are available at many online stores.
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rutwik Belsare さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 28
今までの合計 476
